1988 245DL B230F Auto
Old Apr 17, 2024 | 05:52 PM
BadJimmy's Avatar
Default 1988 245DL B230F Auto
PROBLEM: Car doesn't idle unless you unplug the MAF sensor. I tried a used replacement, didn't solve the problem. I don't know if I have another bad MAF or it's a different problem.
Coupla questions:
1. Does anyone know how to test a MAF sensor for this model?
2. The only visible difference between the 1988 MAF and years after is the missing adjustment screw. Can I use the later one without the screw? Or will that cause problems? Bosch no longer makes the one with the screw but you can get a reman for like $1200. Would prefer not to shell out that kind of dough if it will run one without the screw.
3. There are cheapo versions available, $50 on ebay and $132 from Autozone (probably the same thing.). Are these trustworthy? Very leery.
Old Apr 19, 2024 | 08:27 AM
act1292's Avatar
You have to use the MAF for LH 2.2 fuel injection system - which was used on models up to '88. In '89 they switched to LH 2.4 and the MAF from '89 and later will not work in your car.
Like I posted in your other thread, aftermarket MAFs are shady at best. Avoid the eBay ones. Go search the threads here and on Brickboard and you will find stories of MAFs that don't work out of the box. I have read even the new Volvo branded ones have had issues (they don't sell Bosch replacements anymore).
Old Apr 19, 2024 | 09:11 AM
No, they are not compatible. Only the 007 , 1346645 (85-88) will work.
Old Apr 20, 2024 | 08:31 AM
Zombi's Avatar
Default solution to bad MAF
Are these ECU boxes Chrysler, and has anyone tried sourcing parts from that direction?
Old Apr 21, 2024 | 08:10 AM
act1292's Avatar
These are Bosch ECUs. LH Jetronic is a Bosch fuel injection system.
jigen3
Nov 23, 2014 11:25 AM
dajson
May 29, 2013 07:15 AM
hardluck
Sep 24, 2012 02:56 PM
slimflex2
Aug 15, 2012 11:59 PM
MarksS60
Feb 6, 2012 07:16 PM
