maf sensor
Old Aug 2, 2012 | 05:42 PM
slimflex2's Avatar
Default maf sensor
does anyone know how to test for a bad maf sensor?thank you
Old Aug 2, 2012 | 06:57 PM
colt1911's Avatar
Default Maf sensor
On my 850 and both my v70's I disconect the plug, if the car stalls the maf is good, I'll look it up on my vida asap and post what I findd for you.
Old Aug 2, 2012 | 08:50 PM
slimflex2's Avatar
thank you very much.
Old Aug 14, 2012 | 09:15 AM
daddio18's Avatar
Default problem with my MAF on 850
Hi
I have an 850 GLE that i suspect thaat the MAF is defective.
I disconnected the senssor plug and the motor still runs.
Do you think the MAF is defective?
Old Aug 14, 2012 | 04:46 PM
slimflex2's Avatar
Originally Posted by daddio18
Hi
how is your car running with the MAFF plugged in? do you have any check engine light?
Old Aug 15, 2012 | 01:32 PM
daddio18's Avatar
With the MAF cable plugged in the engine rev's up and down like crazy.
Witht he MAF disconnected it is stable. The check engine is on.
Didn't check if there is a code yet.
The engine keeps running with the cable pulled out.
I also have ABS light on and when the MAF cable pulled when braking the ABS engaged with no reason.
Old Aug 15, 2012 | 04:39 PM
slimflex2's Avatar
it is probably your maf sensor not doing its job well.first of all you might want to try and clean it first and see if that will help.get a maf sensor cleaner and try that first.not hard to do.also you might want to stop by autozone and get the codes.that would be of great help.check for vacuum leak too.check all your vacuum hoses and make sure there are noo cracks or brittled.as for the abs,if the light is on it is probably gettin bad
Old Aug 15, 2012 | 11:59 PM
slimflex2's Avatar
Buy CRC Mass Air Flow Sensor Cleaner 05110 at Advance Auto Parts
try this product first.maf cleaner.
02VolvoS40
Jul 16, 2010 08:12 PM
cpak007
Sep 4, 2008 07:23 PM
Thegoose
Dec 22, 2007 08:08 AM
WagHag
Apr 18, 2006 02:14 AM
Mr Zed
Aug 12, 2005 01:18 AM
