1988 740 GLE Clutch
Old Jul 15, 2007 | 08:32 PM
slim109's Avatar
Default 1988 740 GLE Clutch
So I sort of inherited a 1988 740 gle volvo from my older brother who doesnt drive it anymore.
Some of the inside could be in better condition but I am not to concerned about that. What I am concerned about is the noise that the car makes when the clutch is not pushed in. The noise is sort of like a wawawawa sound that is much more audible inside the car than out. When you push the clutch in the noise slows and then stops after about two seconds. The faster you go when driving the faster the wawa noise gets so I am thinking it might be the clutch fan. Would that make a noise like that? Any other thoughts are welcome?
Old Jul 16, 2007 | 06:26 AM
89_240_DL_Sedan's Avatar
Default RE: 1988 740 GLE Clutch
What you are describing sounds like the throw out bearing which is part of the clutch. If everything is working ok then I would just get used to the noise. The part you are thinking about is the fan clutch which regulates the engine fan speed as the engine warms up and cools.
Old Jul 17, 2007 | 01:33 PM
VolvoDriver's Avatar
perhaps try to put your Volvo on jack-stands and put it in drive...btw, auto or manual?... or rev the engive listen for the sound then.
Old Jul 18, 2007 | 04:28 PM
wojeepster's Avatar
It took me 45 minutes to pull my parents trans to change clutch. It is one of the easier ones. You have to turn the trans 90 degrees for clearance once the bolts are out. I agree it sounds like throwout bearing.
ijourneaux
May 29, 2011 06:30 PM
Scraperondubz
Apr 13, 2009 11:44 PM
kamaradalex
Jun 30, 2008 01:55 PM
talbott357
Dec 31, 2007 06:38 PM
greatnorthern740
May 22, 2007 03:46 PM
