1988 Volvo 245DL suggest transmission oil
Old Dec 8, 2014 | 03:22 PM
smeha's Avatar
Thumbs up 1988 Volvo 245DL suggest transmission oil
Hello,
I own 1988 Volvo 245DL with AW70 transmission.
I've been using before Mobil 1 ATF Synthetic Fluid.
About to do full transmission flush and add additives.
Can someone suggest specific brands and types please?
Old Dec 8, 2014 | 05:09 PM
I've been using Castrol Transmax Import (formerly Multi-Import) ATF, which is specified for late model Toyotas and such. The AW70 is a Toyota transmission, same as used on a wide range of RWD toyotas in the mid 80s to mid 90s, including a lot 2x4 pickups, turbo supras, etc. spec sheet: http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/064FD5179C8D0FFD80257AA90053687A/$File/Castrol%20Transmax%20Import%20MV%20_03521_.pdf
its also widely available.
But, really, any decent brand name Dex/Merc III should be fine. I don't use additives, IMHO, they are snake oil.
Old Dec 8, 2014 | 06:13 PM
smeha's Avatar
Thank you!!!
I will use additives probably since a lot of other people saying they help to clean. Looking at Lucas transmission additive. If you remember we talked in different thread about my OD transmission problem.
Old Dec 8, 2014 | 07:17 PM
ATF's are already full of additives as part of their formula, and are very good at cleaning things.
smeha
Dec 29, 2014 01:16 PM
Red Tractors
Jun 11, 2014 08:50 PM
captn.morgasm1992
Oct 25, 2011 10:46 PM
asheville4me
Sep 4, 2010 06:56 PM
