1989 240 Won't Start, no response from Lambda
Old Jul 5, 2019 | 09:29 PM
FantasticGarlic's Avatar
Default 1989 240 Won't Start, no response from self-diagnostic light [SOLVED]
So I just got this car, a 1989 240 with the B230F, a few days ago and I can't get it to fire. Initially, I got it to run by spraying starter fluid into the intake so I assumed it was a fuel pump issue. Then it randomly started up however was running extremely rough. When jumping the fuel pump straight to the battery you can hear it and fuel comes out of the fuel line when disconnected so that excludes that.
Here is where I'm at; when reading the Lambda codes the EZK (Pin 6) displays code 1-4-4. The ECU (Pin 2) does not display any code or anything for that matter. After holding the button it does not spit anything out. The 1-4-4 EZK code from what I have read seems to be no communication with the ECU so is there is an electrical fault somewhere? I thought it was the fuel pump relay and have purchased another one and will try that when it gets here, but until then I was curious if anyone had any other ideas as to what it may be?
Old Jul 6, 2019 | 02:19 AM
fyi, lambda refers to the oxygen sensor.
it sounds like you could have a sketchy ECU, some early LH2.4 240 ECUs were problematic. pink label or something?
there's a not-100%-complete chart of ECUs here,
https://www.volvoclub.org.uk/faq/Eng...ReferenceChart
Old Jul 6, 2019 | 07:04 AM
jagtoes's Avatar
I would look at the 3 main areas and test them. The radio suppression relay fires the injectors. Get a noid light and check that the injectors are working during the ignition cycle. Next would be the Fuel Pump relay , just replace it with a new one. Also get a fuel pressure gauge and check the fuel pressure at the fuel rail. Just because it has fuel coming out doesn't mean it is delivering 44 psi at the injector. Then check or replace the Crank Position Sensor (CPS) . Before you get into the CPU just do the basic investigation. Good luck and let us know how you make out.
Old Jul 6, 2019 | 10:16 AM
My mistake. Whatever that under hood code reader is called then is what I used.
Originally Posted by jagtoes
I would look at the 3 main areas and test them. The radio suppression relay fires the injectors. Get a noid light and check that the injectors are working during the ignition cycle. Next would be the Fuel Pump relay, just replace it with a new one. Also, get a fuel pressure gauge and check the fuel pressure at the fuel rail. Just because it has fuel coming out doesn't mean it is delivering 44 psi at the injector. Then check or replace the Crank Position Sensor (CPS) . Before you get into the CPU just do the basic investigation. Good luck and let us know how you make out.
The fuel pump relay should be here tomorrow so I'll try that once it arrives. As far as the rest of it I will run down that road after I try the relay. Would a blown relay cause the ECU to not communicate at all with the under-hood diagnostic?
Old Jul 6, 2019 | 12:58 PM
the fuel system relay on 240 has two halves in it, one half powers the ECU and the other half powers both fuel pumps.
there's no radio suppression relay (RSR) on a 240, thats purely a 740/940 thing. the 240 injectors get their power off the fuel system relay, and are fired by the ECU selectively grounding them.
Old Jul 7, 2019 | 02:34 PM
I replaced the fuel system relay to no avail. I bought two of them so I tried both and my symptoms are the same and when I use the self-diagnostic under the hood there is still no response when I check Pin 2. Would the crank position sensor cause symptoms like this?
Additionally, there is no voltage at the #4 fuse with the ignition on and the fuel pump does not prime if that helps any.
Old Jul 7, 2019 | 02:38 PM
jagtoes's Avatar
If the CPS is bad you get no spark.
Old Jul 7, 2019 | 02:59 PM
It will run on starter fluid so there is spark.
Old Jul 7, 2019 | 04:13 PM
the fuel pumps are only supposed to come on about 1 second when you turn the key on, then go off until the engine turns over.
no signal at #2 could indicate the ECU is dead, or the wire from the ECU to the diagnostic block is broken.
Old Jul 10, 2019 | 02:59 PM
I replaced the ECU with a '591'white label ECU and that fixed the problem. I now have a response of 1-1-1 from Pin 2 however, Pin 6 still gives me the 1-4-4 code for some reason. But now the car runs so we can pick away at the little things from here! Thank you, everyone, for your help.
RSV4Rodak
Aug 20, 2018 04:09 PM
droool
Jun 20, 2013 12:41 PM
Moosasaur
Jun 12, 2013 01:35 PM
dlukowsk
Jun 27, 2012 05:14 PM
elky74
Aug 22, 2009 02:40 PM
