1989 244 Heater Slide
Old Jul 29, 2016 | 09:14 AM
Sidewinder7's Avatar
Default 1989 244 Heater Slide
Hi Everyone,
The heater slide in my 1989 244 is very hard to move and won't go clear to the end of the "heat" side. The slides on my other 240's work great. Looking on the web has several different things it could be, but doesn't point to a specific fix. I'd hate to tear the whole heating system apart to find it was something like just a missing a washer on the slider or something, so I was wondering if anyone could tell me if this was a common issue (e.g. slides always bind, check this or its not the slide, check the connection behind it, etc.) and where to start looking.
Thanks
Old Jul 29, 2016 | 10:05 AM
lev's Avatar
lev
Well, you probably need to do some dismantling of the controls to see what's going on. These are cables and they bind with time, dry out, etc. Happens a lot to these things... No magic bullet unfortunately.
Old Jul 30, 2016 | 08:01 AM
act1292's Avatar
You don't need to take apart the whole heating system to diagnose this. It could be one of three things: The heater control valve, the cable itself or the actual lever mechanism. All three of these components are easily accessible. Just remove the kick panel just to the right of the accelerator pedal (assuming not a right-hand drive vehicle). Up by the accelerator pedal is where the coolant hoses come through the firewall. You can see he heater control valve there. Disconnect the cable (just a clip I believe) and try the lever. If it moves freely then the culprit is the heater control valve. If it is still stiff, you need to remove the front of the center console to access the lever. Disconnect the cable from the lever. If the lever moves freely, then the problem is with the cable. If the lever is still stiff, then the lever is binding.
Old Aug 1, 2016 | 08:08 AM
Thanks everyone.. exactly what I needed to start the repair!
dejr
Jun 25, 2012 10:04 PM
rspi
Aug 29, 2010 01:59 PM
sdguy
Apr 18, 2010 02:18 PM
ra96099
Feb 20, 2006 01:30 AM
floryed
May 3, 2005 09:55 PM
