1989 turbo fuel delivery problem?
Old Sep 29, 2015 | 10:19 PM
Dean01's Avatar
Default 1989 turbo fuel delivery problem?
I have a 89 Volvo just picked it up turbo wagon it runs good pulls alright but runs too ritch and craps out at 4000 to 4500 rpm if ur full throttle but if u back off to 3/4 throttle it pulls good all the way to 6 u have to find the sweet spot tho to hit high rpm within 1/4" on the gas pedal? Anyone have any ideas?
Old Sep 30, 2015 | 04:00 PM
jagtoes's Avatar
Please start a new post
Old Sep 30, 2015 | 04:05 PM
jagtoes's Avatar
Originally Posted by bfoskuhl14
My volvo 740 was working before I changed the fuel filter. How do I relieve the pressure in the fuel line, or would it be something different?
Check again to make sure you have power to the pump and it is grounded. Can you hear the pump start when you turn the key to start. Did you kink the plastic tube from the filter to the pump. Check our work because if it ran before you changed it then it should run after . If in doubt reinstall the old filter and see if it runs again.
Old Oct 1, 2015 | 04:10 PM
I moved this to a new thread since its rather unrelated to the old thread.
sounds like fuel starvation to me, I concur with jagtoes.
petergreene
Sep 5, 2013 05:53 AM
anomalousclouds
May 16, 2010 12:49 AM
DavesVolvo
May 11, 2010 08:28 PM
SC Surfer
Sep 24, 2008 05:21 PM
Mr_Jake
Jan 8, 2008 09:56 PM
