1989 Volvo 240 stuck with bright lights only
Old Dec 24, 2010 | 02:10 PM
vwzoo's Avatar
Default 1989 Volvo 240 stuck with bright lights only
My 1989 Volvo wagon has bright lights only. I can't get the light switch to dim them. Any suggestions how to fix this?
Thanks
Dave
Old Dec 25, 2010 | 02:35 AM
there's a relay in the engine compartment bolted on the fender near the overflow bottle that controls the highbeam/lowbeams. its a rectangular thing attached to a metal bracket, wires plug into the bottom. the dimmer switch on the steering stalk sends pulses to this relay, which cycles high,low beam. I believe its p/n 1307991.
before swapping the relay, I'd probably want to find the wiring schematic and verify that the dimmer stalk does in fact get to the relay plug (hook a volt meter up to the relay's input that comes from the stalk, have someone cycle the stalk and see if you see volts on/off. the switch might be to ground, then you'd use an ohmmeter setting instead of volts). I don't have a 240 manual handy so i can't give you any pin numbers to sort this out. if the control signal isn't there, then its a wiring or switch issue.
ahhh, google to the rescue, http://oak.cats.ohiou.edu/~ridgely/V..._240__1990.pdf on page ... ugh, its confusing and complicated the way its drawn, and I don't even see the high/low switch on there, but I think it must be the brown wire to pin 31B on the beam step relay, and I think its switched to ground, not to power
Newport_j
Dec 26, 2011 03:54 PM
Dietzl
Apr 23, 2010 04:08 PM
imacuser12
Oct 22, 2006 10:10 PM
baldy7
Dec 21, 2005 02:30 PM
Rich Solano
Apr 21, 2005 09:54 AM
