I cannot keep the bright lights on
Old Dec 25, 2011 | 11:57 PM
Newport_j's Avatar
Default I cannot keep the bright lights on
I recently discovered a problem in that I cannot keep my bright headlights on. When I move the switch on the steering column to the correct position the lights come on, but the switch on the steering column does not stay there. I have to hold there with my index finger. Of course, this makes driving very difficult having to hold the switch all the time.
What could be wrong and how do I correct it?
Any help appreciated. Thanks in advance.
Newport_j
Old Dec 26, 2011 | 01:46 PM
DavidB's Avatar
What position do you have the headlight switch (dashboard left of instrument panel) in? The headlight switch must be in position before the high beams will function. If it is in the "0" position,that only turns on daytime running lights. Front and rear parking lights and license plate lights will also be on but highbeams will only flash when you pull on the stalk.
Old Dec 26, 2011 | 02:05 PM
Newport_j's Avatar
Default I give it a try
Thanks very much, I will try it. it may have been moved by a mechanic last week.
Newport_j
Old Dec 26, 2011 | 02:56 PM
DavidB's Avatar
with me it's usually the spousal unit.
Old Dec 26, 2011 | 03:54 PM
Newport_j's Avatar
Default Bright lights
That was it. Thanks very much!
Newport_j
bigvolvo
Oct 2, 2010 07:05 PM
Dietzl
Apr 23, 2010 04:08 PM
imacuser12
Oct 22, 2006 10:10 PM
baldy7
Dec 21, 2005 02:30 PM
Rich Solano
Apr 21, 2005 09:54 AM
