1989 volvo 740 Car wont go in reverse
Old Jan 12, 2009 | 04:56 AM
pwnage's Avatar
Default 1989 volvo 740 Car wont go in reverse
Hi,
I am brand new to driving a volvo and brand new to this forum, I am not certain about these little mechanical problems that occurs when volvos cars get old.
About a month ago, my car started lagging after I put it into gear, my car would be in gear and my foot on the gas but it would lag for a few seconds before it would catch into gear.
As of two days ago, everything is working normal, however; now, when i put my car into reverse(it is an automatic) and i press on the gas it just stays stationary, a few people have told me that its the transmission and if I want to fix it then its going to cost more than the car. I was hoping someone could help me out by identifying this problem so I can save some time/money by not going to the mechanic to get it inspected right away. Thank you
Old Jan 12, 2009 | 07:47 AM
dwaino@live.com's Avatar
Default RE: 1989 volvo 740 Car wont go in reverse
Check the transmission fluid. If its low, reverse is the first thing to suffer. If its low then check to see where its leaking. Either a seal or maybe one of the cooling lines might be bad. My experience is that Volvo automatic transmissions are extremely tough and durable... One more thought is I once had one that sat for a few years and the brakes where sticking causing the car to respond as you describe. Also, check the E-break. They are notorious for sticking... Stop on a hill, put the car in neutral and let off the brake. If the car doesn't role then you have brakes sticking... Hope this helps...
Peace, Dwain
Old Jan 12, 2009 | 08:25 PM
tedv's Avatar
If your fluid is not low, then your transmission is bad...
Old Jan 12, 2009 | 09:06 PM
Right Tedv...
Old Jan 12, 2009 | 11:41 PM
fredbyte's Avatar
I'm new when it comes to automatics; we just picked one up. Could it also be the starter inhibitor switch at the gear shift?
Gardenhands
Feb 20, 2021 10:23 PM
suze
Jan 30, 2014 07:42 AM
Nakita&jeff
May 6, 2013 09:53 PM
alpine
Aug 12, 2010 04:04 PM
S70driver
Jun 1, 2009 08:17 PM
