1990 740 fault codes
Old Jan 18, 2015 | 04:43 PM
Daano47's Avatar
Default 1990 740 fault codes
where would the signal to coldstart valve that is either shorted to ground or missing on 1990 Volvo 740 wagon. that is one of the trouble trouble codes that is on my car
Old Jan 18, 2015 | 04:56 PM
bosch or regina?
I only have 91 and later wiring diagrams, but they are likely the same. hmm, 1992, looks like they got rid of it for bosch systems, anyways, I'm not finding the cold start injector at all?
ah, ok, the 1991 LH2.4 diagram DOES show the cold start injector... injector gets its power from the 'radio suppression relay', same as the other injectors, and is grounded by ECU pin 32 to turn it on (ECU pin 18 turns on the main injectors)... Regina also uses pin 32.
Old Jan 19, 2015 | 01:21 PM
Daano47's Avatar
what would cause a knock sensor on 1990 volvo 740 show absent or faulty? I have replaced the sensor once and still shows the trouble code...
Old Jan 19, 2015 | 01:36 PM
maybe a broken wire ? knock sensor has a green and black wire, they go through 8-pin connector F (left suspension tower) and black (ground) connects to ICU pin 12, while green (signal) connects to ICU pin 13. The drawing shows this connection as a shielded wire (where black is teh shield, green is the inside conductor). the LH2.4 ICU is mounted on the driver (left) side of the firewall behind the dashboard.
btw, why did you post this as a reply to a 3 year old thread on a completely different topic ?
p.s. I moved these posts to a new thread.
Old Jan 19, 2015 | 06:35 PM
Daano47's Avatar
I was trying to find the right topic and thread wasn't sure which one to post on!
Old Jan 19, 2015 | 06:40 PM
a new car, with its own set of problems, should post a new thread.
v1lcins
May 20, 2022 10:53 AM
mattem
May 14, 2020 08:39 AM
anthonyx
Aug 9, 2015 02:29 PM
craigshensel
Jun 13, 2012 03:11 PM
texasinger
Jul 22, 2011 12:38 PM
