1990 740 Turbo Wagon Code Problem
Old Jun 21, 2005 | 02:45 PM
gkvinov's Avatar
Default 1990 740 Turbo Wagon Code Problem
I have a 1990 740 Turbo Wagon with the following reoccuring codes. 213 Throttle switch signal wide open (replaced switch didn't help). 312 Knock/ fuel enrichment signal missing. 231 Lambda adjust (probably because of the wide open throttle signal). I've checked the connections at the sensors and as far as I can trace them. The general condition of the car is excellent. Does anyone have any ideas? Maybe if the 213 and 312 connect somewhere together. Computer problem?? Thanks GV
Old Jun 21, 2005 | 04:22 PM
Ignavus's Avatar
Default RE: 1990 740 Turbo Wagon Code Problem
You would need to check continuity in the wiring from the TPS and knock sensor all the way to the ECU. Does it exhibit any drivability problems?
Old Jun 21, 2005 | 04:35 PM
How does the engine harness look?
Old Jun 22, 2005 | 07:54 AM
gkvinov's Avatar
The wire harness looks to be in good condition. The car is running very rich, probably because of the wide open signal, but is driveable. It idles rough. I can trace the wires from the knock sensor and TPS to about the drivers side wheel well where it goes into the main harness. Don't know how to trace it from there. Thanks for the help. GV
Old Jun 22, 2005 | 08:41 PM
Ignavus's Avatar
With those symptoms ,the harness should be tested at the ECU. But, I would also be suspicious of a bad ECU. If you can locate one cheap at the local auto recyclers ,or by prowling eBay, it may be advantageous to try a swap.
mattem
May 14, 2020 08:39 AM
craigshensel
Jun 13, 2012 03:11 PM
volvoQ's
Sep 26, 2010 01:45 AM
markisboss
Apr 2, 2008 03:44 PM
gkvinov
Jul 5, 2005 07:42 PM
