1990 740T Rim size?
Old Nov 27, 2011 | 04:51 PM
Gregman's Avatar
Default 1990 740T Rim size?
So I bought someones old snow tires with rims in good condition.
The tires size was the same so I thought great no problem.
However after doing a test drive I realized that the front wheels and rims were rubbing on the struts?
Anyway I quickly removed them.
Is there a certain depth rim that will work better on 740's?
Thanks Greg
Old Nov 27, 2011 | 08:09 PM
jagtoes's Avatar
Thanks Greg
So what was the car that they came from. Do we assume another Volvo. Did you measure the off-set to see if they were the same?
Old Nov 27, 2011 | 11:43 PM
Gregman's Avatar
Yes they cam from an old 850 wagon.
No I did not measure the....... what's an off set?
Old Nov 28, 2011 | 03:27 PM
jagtoes's Avatar
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel (measured in millimeters). I believe there is a difference from an 850 and your car. The result would be interference of the tire and either the suspension or the body work. Depending on whether it is a positive of negative offset you may be able to get spacers or maybe you can't use these wheels.
Old Nov 28, 2011 | 11:30 PM
swiftjustice44's Avatar
beginning w/ 850's, Volvo's were front wheel drive...the wheel offset is different although the bolt pattern is the same. You need spacers to run them. Incidentally, the 90 turbo had 16x6.5 Hydra wheels standard.
Old Nov 29, 2011 | 10:51 AM
Gregman's Avatar
How can I determine the spacer size needed?
Old Nov 29, 2011 | 11:06 AM
The simplest way is to take pictures of the wheels you bought and get on turbobricks.com and ask in the maintenance section. I don't keep up with that stuff as I have a completely unsupported bias against spacers. I will tell you this...the cheapest thing to do is either eBay the ones you have or CraigsList 'em and buy some correct rims. Spacers seem to command a premium price. Also, depending on the existing wheels, the front takes more of an offset than the rear.
Old Nov 29, 2011 | 04:54 PM
jagtoes's Avatar
You do the math. Spacers cost about $50-$100 each .
740turbo1990
Jan 5, 2012 05:32 PM
volvoQ's
Sep 18, 2010 10:23 PM
volvoQ's
Sep 7, 2010 05:29 PM
chadoll
Oct 20, 2009 09:28 AM
m4gician
Jan 3, 2007 02:11 PM
