1990 740T voltage drops off at startup
Old Sep 6, 2010 | 08:49 PM
volvoQ's's Avatar
Default 1990 740T voltage drops off at startup
It runs fine, but right after starting up, the voltage drops off, sometimes I have to give it a little gas to keep it running, and then it runs fine and the voltage stays good. The battery is being charged fine, I check it with a voltmeter, it reads around 13.8 V consistently and it has a new battery. I am just trying to figure out why it is doing this at startup.
Thanks!
Old Sep 7, 2010 | 02:31 AM
Typhoon's Avatar
My 90 turbo wagon sort of does this sometimes. Every now and then, the charge and ABS light will come on and stay on till I give it a few revs, then it's fine.
I just think it's the regulator on the alternator not getting "excited" till the revs rise.
Regards, Andrew.
Old Sep 7, 2010 | 12:15 PM
swiftjustice44's Avatar
^^^This ABS lights will light anytime it doesn't see 12 volts. Most always, ime, it is the excitor wire or circuit. Sometimes a good gase ground helps. I added a 12 gauge case ground on my 144 but it still occasionally has this issue.
Old Sep 7, 2010 | 05:29 PM
Typhoon's Avatar
Yes, the ABS system is pretty clever, it protects itself from over/under voltages and disables itself as part of it's initial self test. Unfortunately, I learned all about it chasing my ABS system problems, all of which are now fixed!
I should also add that my alternator also has a six month old regulator/brush holder in it too, so I think you are onto something with the exciter wire/ground.
Regards, Andrew.
740turbo1990
Jan 5, 2012 05:32 PM
Gregman
Nov 29, 2011 04:54 PM
ejpomeroy
Oct 4, 2011 06:06 PM
Kenwood
Apr 18, 2011 11:04 AM
volvoQ's
Sep 18, 2010 10:23 PM
