1990 Volvo 740 GL Loss Of Power?!
Old Mar 17, 2011 | 07:15 PM
MNWILD's Avatar
Default 1990 Volvo 740 GL Loss Of Power?!
Hi everyone, My brother just changed my water pump & timing belt on my Volvo 740 last week. The belt never broke but he did put on a new harmonic balancer & it was timed right & it runs real smooth but i can tell it lost a lot of power. I'm not throwing off any engine codes. Could it be my cat plugged? I did run seafoam in it. Any ideas? It seems to idle smooth but just seems like something is pluged & there is way less power. Not that it had power in the first place! lol
Old Mar 17, 2011 | 07:31 PM
MNWILD's Avatar
Also, it doesn't over heat & it runs cool. It doesn't get hot & the motor seems to run great! No engine lights lit up on the car. I'm stumped!
Old Mar 17, 2011 | 08:49 PM
MNWILD's Avatar
Anyone?
Old Mar 17, 2011 | 09:41 PM
guest01's Avatar
if there wasn't a problem prior to the recent work, the obvious first place to look would be all the work performed. maybe a connect or hose or something came loose.
Old Mar 18, 2011 | 01:30 AM
Titan Joe's Avatar
I would think that you put the timing belt on one tooth off. When you line up the timing marks on the belt, the crank pulley mark is not really on the mark. Look at the picture at the bottom pulley. You have to eyeball the alignment and you can turn it back a bit to check. I think that there's a double line for the crank. That's all I can really think of, other than what guest01 said.
Old Mar 18, 2011 | 07:15 AM
MNWILD's Avatar
My brother printed out this picture also so i know he timed it right. Very weird!
Old Mar 18, 2011 | 08:19 AM
jagtoes's Avatar
Check the timing and see what you have. If it is off then you need to reset the belt. Does the engine sound smooth as you accelerate? After driving it is the cat glowing.
Old Mar 18, 2011 | 08:20 AM
guest01's Avatar
he......... so you haven't seen for yourself that the timing is actually on?
Old Mar 18, 2011 | 06:15 PM
MNWILD's Avatar
My brother is really good a auto repair so i'm not worried about the timing. I might check out if the cat is plugged. If i let it sit an idle for a long time will the cat still glow?
Wesley brown
Oct 7, 2014 10:12 AM
firepenguinz
Jul 30, 2012 08:20 AM
MNWILD
Jul 27, 2011 04:53 AM
MNWILD
Mar 27, 2011 03:57 AM
the244life
Apr 16, 2010 09:20 AM
