fault code 2-4-1 in 1991 volvo
Old Mar 28, 2011 | 09:57 AM
vipul_vips's Avatar
Default fault code 2-4-1 in 1991 volvo
Hello,
I am trying to understand what I need to fix in my 1991 volvo which has a check engine fault code of 2-4-1.
Does someone have instructions on what I need to check and how to check?
I appreciate your responses.
Thanks in advance.
Old Mar 28, 2011 | 10:34 AM
jagtoes's Avatar
Originally Posted by vipul_vips
Hello,
Thanks in advance.
This is an EGR Malfunction.
Old Mar 28, 2011 | 10:46 AM
vipul_vips's Avatar
Hi jagtoes, Thanks for your response. I know it is EGR malfunction (looked up the haynes manual), but I am trying to find instructions on how to fix the issues. WHat should I be troubleshooting? The haynes manual does not do a good job of explaining.
Thank you for your help (in advance).
Old Mar 28, 2011 | 04:02 PM
jagtoes's Avatar
1st what model is it ? A 240 or a 740 or a 960 , etc?. I would using a vacuum pump verify if the EGR valve holds vacuum. If not then the diaphragm is bad and you would need a new valve. I suspect you know that this is a pricey item. Also check any wiring connections and clean them.
Old Mar 28, 2011 | 05:29 PM
vipul_vips's Avatar
Hi jagtoes,
the model is 1991 volvo 740 Station Wagon (non-Turbo).
would you happen to have illustrated instructions for this?
v1lcins
May 20, 2022 10:53 AM
Chaver
Aug 1, 2013 06:12 PM
wantheman9884
Oct 24, 2012 05:05 PM
sevans0579
Dec 23, 2011 03:47 PM
rchchmb
May 11, 2008 09:57 AM
