1991 940 Power Seat Switch
Old Dec 29, 2008 | 06:00 PM
spackelman's Avatar
Default 1991 940 Power Seat Switch
Anyone know howthe switch comes apart. I have 12 volts to the switch and0 volts out. I know the stop button does stick.
I wantto take the switch apart to service it.
Thanksfor any help...
91 940 turbo
Old Dec 30, 2008 | 01:51 AM
tedv's Avatar
Default RE: 1991 940 Power Seat Switch
Pull theplastic assembly where the switch sitsUP from the front, it could be pretty tight. The back part is attached to the seat with a screw at the end. There are two bolts on the bottom holding the switch in place.
Old Dec 30, 2008 | 01:03 PM
spackelman's Avatar
Thanks,couldn't figure out how to get the front screw (torx) out.
how about the switch itself?
Old Dec 30, 2008 | 04:01 PM
tedv's Avatar
You can try to unscrew that front torx too, sometimes it's hard to get to... The switch itself, comes apart, be careful not to lose little springs and bb's. These switches, up to 1991 are a pain the way they are designed-a lot of crap falls in there, makes them malfunction. Especially the RED stop button one; if it's stuck then nothing works. The ones 1992 and up are better.
Old Dec 30, 2008 | 06:58 PM
spackelman's Avatar
Found this:
http://www.swedishbricks.net/700900F...or-Seats1.html
Apparently the switch doesn't come apart. You pry the rockers off to service them. like ted says. But it looks like the circuit board and components will pull out from the bottom, don't know.
Heres the schematic, can some explain what the diodes are for.
http://i137.photobucket.com/albums/q...tschematic.jpg
volvoritchie
Nov 16, 2012 05:45 PM
mbsimmons
May 7, 2010 05:35 PM
mcmuggles
Feb 25, 2009 11:54 PM
spackelman
Dec 5, 2008 01:30 AM
DJboozeAlot
Nov 3, 2006 12:21 AM
