1992 240 4cyl wagon: fuel pump relay Ry2 coil issue
New member here, and as with many seeking your expert input!
We have a 1992 240 4cyl wagon, that has been passed around since a family member purchased new. Only 112,000 miles. Recently it started dying, and/or not starting. With the age of all the components, and as a preventative, I replaced both fuel pumps, and their filters. The car continued to misbehave. I resorted to removing the cover of the fuel pump relay, under glove box, and observed that when not starting or dying only the Ry1 relay coil pulls closed. The Ry2 side remains open. On the times both close, the 240 starts and runs fine. I see this same symptom with both new relays, I just can't figure out the cause.
Is there another component with this system that is famous for causing this random behavior?
Thx for the input! I totally agree with testing parts before replacement. My challenge has been the fact that the issue is intermittent, and the driver in this case has near zero understanding of cars, meaning if it dies, I'll get a phone call and need to remind them to put it in park, and turn the key again.
As many Volvo forums list fuel pump relays, and even the dual pump system as most frequent issues with the 240 series, I feel good about installing the new Bosch pump and filter. I will get the recommend Stribel relay, and now have better sources for my 240 Volvo parts than Amazon Thank you again!
1995Volvo850
09-28-2022 12:20 PM
montysano
09-09-2008 11:52 AM
