1992 240 m47 manual transmission help!
Old Mar 24, 2019 | 10:09 PM
Iagtroop's Avatar
Default 1992 240 m47 manual transmission help!
My transmission began making a knocking noise with the clutch pedal out, so I figured I would start by replacing the input shaft bearing.
One problem, I can’t figure out how to get the input shaft bearing off of the input shaft. If anyone has any tips please let me know. I am having a super hard time with this. How many snap rings need to be removed in order to take this off? I have removed one big one and one small one bit this bearing isn’t moving. Please help
Old Mar 26, 2019 | 09:05 AM
Zombi's Avatar
Perhaps you might consider obtaining a service manual.
Have you cleaned the transmission and examined all of the bearings,gear teeth, and looked in the bottom for metal?
Does the bearing make noise, and how tight does it feel?
With the clutch pedal depressed while halted if in gear you only have the throw out bearing spinning.
Has the throwout bearing been examined?
Old Mar 26, 2019 | 04:55 PM
transmission repair is non trivial. transmissions require the shafts be properly shimmed to the correct amount of end play, and so forth, the proper rebuilding manual is a must. there's literally 100s of parts inside that M47.
Old Mar 26, 2019 | 05:50 PM
Iagtroop's Avatar
Zombie, yes I finally found a service manual online for this transmission. Seems there is a lot to it.... the noise only occurs with the pedal out. With the pedal in the noise goes away, leading
me to suspect the input shaft bearing. I wish the problem was as simple as a throw out bearing. Thanks for the reply
Old Mar 26, 2019 | 05:52 PM
Iagtroop's Avatar
PIerce, I have found a rebuild manual and it seems I have a lot of work ahead of me... I was hoping to be able to remove the input shaft bearing from the front and put a new one on without having to remove any internals... but I’m not that lucky this time around. Thanks for your reply
Old Mar 26, 2019 | 06:27 PM
does it happen in neutral when you're fully stopped? and how fast is this knocking noise when the engine is idling in neutral ?
the thing is, on a manual, all the gears are turning all the time, but the shafts aren't engaged until you select a gear.
Old Mar 26, 2019 | 07:11 PM
Zombi's Avatar
Default other knoledge
The Turbo brick people did a post. https://forums.tbforums.com/archive/.../t-250481.html.
You may find it helpful.
I thought it was well written, but I've done more R&R than building.
Old Mar 27, 2019 | 06:24 PM
Iagtroop's Avatar
Pierce, the knocking speed goes along with the engine speed... at first I thought it was the engine but when laying underneath was definitely the transmission.
so I finally got the bearing off without having to take the input shaft out... don’t ask how... but after seeing how tight the bearing was pressed I’m afraid I’m not going to be able to get a new bearing pressed on without damaging something else inside the transmission. So I need to get the input shaft out.. in order to do this - per the green book- I need to remove the front countershaft bearing which lets the countershaft drop enough to pull the input shaft out.
So now I am in search of this special puller to remove the countershaft bearing.. getting closer hopefully.
Old Mar 27, 2019 | 06:28 PM
Iagtroop's Avatar
Zombi, yes that thread is helpful to me but some of the links aren’t working for me. I’ll keep looking.
Has anyone seen an exploded view of the m47 with a parts list with part numbers.?? I have just been finding a picture with numbers but no parts to go along with the numbers
Old Mar 27, 2019 | 06:37 PM
Iagtroop's Avatar
The attached pictures is what I’m trying to explain when I say removing the countershaft bearing will allow the countershaft to drop a little so the gears on the input shaft can clear the gears on the countershaft. The top illustration shows what should happen I think...
Old Mar 27, 2019 | 09:20 PM
try here for the parts listing,
https://www.volvopartswebstore.com/s...rimLevel=28242
Old Mar 27, 2019 | 10:20 PM
Zombi's Avatar
clam shell puller time. perhaps with heat?
Old Mar 27, 2019 | 10:59 PM
Iagtroop's Avatar
Pierce that’s exactly what I’m looking for perfect! Thank you so much... but can you see numbers beside the parts? I can’t but I can just count down the page I guess. Either way big help!
this is what the countershaft bearing looks like... so I will need some type of puller with small arms to get into between the rollers and push off of the actual countershaft. I can take a pic of the actual bearing tomorrow and a picture of the type of puller I’m thinking of.
Old Mar 28, 2019 | 08:09 AM
Iagtroop's Avatar
SO here’s is the bearing and the puller that Volvo recommends. I am on the search for something similar. I’ll let y’all know what happens. Thanks for the help
Old Mar 28, 2019 | 05:10 PM
Zombi's Avatar
I have an 89 M47 that I know nothing about. Came in a 245 parts car that had an engine fire. 200+k miles and no history
Old Mar 28, 2019 | 09:05 PM
Iagtroop's Avatar
Want to sell it?
Old Mar 28, 2019 | 09:44 PM
  #17
Zombi's Avatar
PM me please
Old Mar 29, 2019 | 01:58 PM
  #18
Zombi's Avatar
Default alternatives to an m 47
www.aaronreedbaker.com T5 swap.
Something to spend lottery winnings on. best of luck
Old Mar 29, 2019 | 03:22 PM
  #19
there's a zoom or something button that makes hte picture bigger. 'view fullsize'... anmd then, I like to right click 'open in new window' and drag that window so I can see both it and the parts listing side by side...
Old Mar 31, 2019 | 01:15 PM
  #20
Iagtroop's Avatar
To whom it concerns..... I was able to remove the counter shaft bearing by prying it out with a set of crooked end needle nose players.. and I took the 5th gear housing off to allow the counter shaft to drop in the front.
the input shaft pulled out so now I am waiting on a new inpitbshaft bearing and I will try to put this thing back together. Thank you to everyone who helped me through this... hopefully it works when I put t back together.
Check out the countershaft tip... it’s pretty chewed up. But the bearing rolls smooth and does not look bad at all. Maybe this is where the knocking was coming from. Who knows??? Here are some pictures of the transmission being torn apart maybe they will help some one in the future. Thanks again
