1992 240 m47 manual transmission help!
Old Aug 19, 2020 | 05:21 PM
  #21
bcg1's Avatar
I'm replacing my front countershaft and input shaft bearings. How did you extract the input shaft bearing? Also, can you describe how you used angle pliers to remove the countershaft bearing, pull one side and then another? Your c/s bearing appears to be in good shape.
Thanks,
Byron
Old Apr 28, 2024 | 09:15 PM
  #22
dave941's Avatar
Default How to remove fifth gear housing
Originally Posted by Iagtroop
To whom it concerns..... I was able to remove the counter shaft bearing by prying it out with a set of crooked end needle nose players.. and I took the 5th gear housing off to allow the counter shaft to drop in the front.
the input shaft pulled out so now I am waiting on a new inpitbshaft bearing and I will try to put this thing back together. Thank you to everyone who helped me through this... hopefully it works when I put t back together.
Check out the countershaft tip... it’s pretty chewed up. But the bearing rolls smooth and does not look bad at all. Maybe this is where the knocking was coming from. Who knows??? Here are some pictures of the transmission being torn apart maybe they will help some one in the future. Thanks again
I can't figure out how to remove the fifth gear housing.
i don't have the counter shift bearing out yet. When it comes out will the fifth gear housing slip off? I assume the tapered roller bearing is the rear needs to be removed as well?
mattlach
1998-2000 model year V70
Feb 23, 2018 10:04 PM
Johnnnnnn
Oct 22, 2015 10:45 PM
LOVEvolvos
Sep 14, 2012 11:28 AM
Titan Joe
Feb 4, 2011 07:22 PM
mudpie
Jan 14, 2011 08:20 PM
