1992 740 Wagon V Belt HELP!!
Old 08-03-2007 | 07:28 PM
beecho's Avatar
Default 1992 740 Wagon V Belt HELP!!
Anybody know or have any pics on the proper installation of the V-belt for a 92 740 wagon. There is no belt at all on my A/C Compressor. I need to get this fixed, especially with this heat!!! Any help would be great.
Thanks
Beecho
Old 08-07-2007 | 01:22 AM
VolvoDriver's Avatar
Default RE: 1992 740 Wagon V Belt HELP!!
hmm, interesting...well, you going to first want to fix it. get under the Volvo and all around it, look at the compressor and the way it's mated to the block. You should understand the axial function for adjustment of belt tension/compressor placement. once you understand this, you should begin to see a 10mm bolt that runs perpendicular to the compressor, the mechanical principal of this is to push the compressor towards a particular direction while the mating components hold it at a fixed point via axis. be sure to understand that the compressor will not move unless you loosen the bolts which lock the axial play. I believe the belt size is 13mm X 975mm. hope this helps.
mtsumedi
11-13-2010 08:16 PM
volvoQ's
09-26-2010 01:45 AM
volvoQ's
09-19-2010 06:28 PM
jwandhistools
04-17-2009 12:05 AM
Glockness
04-07-2008 07:36 PM
Quick Reply: 1992 740 Wagon V Belt HELP!!
