1992 940g fuel problems
Old Sep 22, 2007 | 11:08 PM
diablocorey2's Avatar
Default 1992 940g fuel problems
Hello, I am looking to buy a Volvo 940g from my grandma and she said she will not sell me the car till I get it to run. I am having problems getting fuel to the motor. I replace thefuel pump in the gas tank this week and now I am clearly at a loss. I have no idea were to go from here, it has more than 2 gallons of gas in it and nothing, as long as I spray starter fluid in the car it will run but nothing if not. Please help me find out what is wrong, I need a car and this will be my first one, so help me out thanks!
Old Sep 23, 2007 | 12:06 AM
83242GT's Avatar
Default RE: 1992 940g fuel problems
How is the external fuel pump, its the high pressure pump that actually gives the fuel system its pressure, i would check to see if thats working right. i would also check fuel pump relays to see if they are actually giving power to the external fuel pump.
Old Sep 23, 2007 | 09:50 AM
blue goose's Avatar
Depending on when the fuel filter was last changed it could be all clogged up.
Old Sep 23, 2007 | 10:09 AM
The 940 only has one fuel pump in the tank.
I would check the fuel filter first.
Then you need to see if you have injector pulse.
If you have injector pulse then it is only a fuel flow problem.
If you don't have injector pulse then you could have a bad relay,flywheel speed sensor,fuel pump relay,ETC
Old Sep 23, 2007 | 02:48 PM
funnyguy44444's Avatar
Definitely replace the fuel filter. If that doesn't do it then check the relays.
Old Sep 25, 2007 | 08:49 PM
There is no fuel pulse, there is noteven a smell of gas with some hoses going to the injector, I have replaced the fuel pump and screen, plus relay, and fuel filter, and I am not real sure wehre to go from here.
xDread92x
Jul 1, 2013 04:55 PM
harebearva
Aug 20, 2012 02:24 PM
940glowner
Dec 15, 2009 09:21 AM
bhasken
May 28, 2009 10:50 PM
bev052185
Oct 29, 2007 05:49 PM
