1992 volvo 240 shaking
Old May 14, 2017 | 06:29 PM
Dan Knieriemen's Avatar
Default 1992 volvo 240 shaking NEED HELP question
hello my name is dan i am 22 years old and i am from VA and currently live in san diego
so i am stuck my car is shaking and vibrating violently in the front and back when i slow down under 20 mph i changed my rotors and my pads and i have no clue what it could be
Old May 15, 2017 | 06:17 AM
act1292's Avatar
It could be a frozen u-joint - most likely the rear u-joint. Remove the 4 bolts that connect the drive shaft to the differential. Check the u-joint there. It should swivel free and easily. If there is any binding then it needs to be replaced.
Old May 15, 2017 | 06:27 AM
John Arsenault's Avatar
While your under the car and grab the rear of the transmission and see if you can wiggle it from side to side. A bad transmission mount can cause that vibration. I had a vibration that would start just as slowed down to come to a stop and or if I backed up in reverse, and it was the transmission mount.
dillon240
Mar 26, 2012 11:52 PM
Volvo_n00b
Feb 26, 2011 01:08 PM
EllisB
Dec 2, 2010 01:53 PM
requiet
Sep 5, 2010 02:45 PM
joe900
Aug 4, 2010 06:47 PM
