1992 Volvo 240 Wont Crank
Old Jul 23, 2014 | 11:07 AM
xDread92x's Avatar
Default 1992 Volvo 240 Wont Crank
Hey everyone. I have noticed the last few weeks my crank has gotten weaker and more extended over time. I have never came to the car being dead. Whatever is going on has slowly gotten worse over time. All the lights in the dash light up and radio comes on, etc. The car is acting as if the neutral safety switch is faulty. I cleaned this thing a year ago so I don't believe its the culprit and as I said the car has cranked weaker over time. I am thinking its a possible starter or starter solenoid issue. Maybe, just maybe alternator or ignition problem. Thanks all.
Old Jul 23, 2014 | 02:46 PM
lev's Avatar
lev
How about the battery getting weaker? Measure the voltage, etc. NeutSaf. switch if bad prevents any starter action.
Old Jul 23, 2014 | 02:51 PM
Bumblebeeman's Avatar
I have herd many a story about faulty CTS(Coolant Temp Sensor) causing hard starts.
Old Jul 25, 2014 | 10:30 PM
scrumblero's Avatar
maybe check your ground cables to make sure they aren't loose or frayed out.
Old Jul 25, 2014 | 11:30 PM
frst thing to check with slow crank is battery voltage. then check the voltage at the starter + terminal to the starter body. if they are significantly different during cranking, the wires are bad. if the battery voltage is low, the battery and/or charging system are bad.
lewis s.
Dec 3, 2017 09:45 PM
wolfman2099
Sep 24, 2014 07:27 PM
xDread92x
Mar 31, 2013 02:18 PM
xDread92x
Aug 18, 2012 03:18 PM
pismo
Jul 20, 2008 04:28 PM
