1992 VOLVO B-230F FI Sensor Removal - How?
Old May 4, 2024 | 06:37 AM
abro's Avatar
Default 1992 VOLVO B-230F FI Sensor Removal - How?
Hi and Hello:
I am trying to change the Fuel Injection (FI) Temperature Sensor located on the driver's side of the B-230F engine. It's a bear to change as lots of "stuff" has to be removed to access the sensor and connector. Short story, FI Sensor is an original sensor from my 1992 VOLVO DL-240, 140k miles, all original. A buddy gave me this new sensor, so I decided to install it in my car. I guess I should have placed it on the shelf as I started a daunting task.
After several hours of removing the AIR Control Valve and several hoses, I thought I could access it after this removal. Now more interference. My question is this:
How do you change this sensor? Removal of the Intake manifold? Wiring to the starter motor?
Thanks in advance. You guys are the best for VOLVO experience and knowledge.
Old May 5, 2024 | 07:59 AM
jagtoes's Avatar
I removed my 740 one years ago but seem to recall I had to remove the throttle body . Removed the intake duct work. remove the IAC and then disconnect the few wire clamps that held the FI wire harness. I then was able to get an extension with a deep thin socket to remove it. Had to move the wiring around but it can be done.
bobbybo
Volvo XC40
Dec 5, 2023 05:36 AM
Dunlin1
Volvo XC40
Aug 24, 2021 03:54 PM
91shelby
Feb 15, 2013 03:22 PM
patricka
Nov 24, 2012 06:33 PM
AAER
Apr 15, 2007 03:38 PM
