temperature sensor
Old Apr 14, 2007 | 12:46 AM
AAER's Avatar
Default temperature sensor
can anyone tell me if temp. sensor would help mpg?... and also besides o2 sensor , are there any other sensors on a 1992 240 that you could think of? how do you locate and change temp. sensor etc.?? thanks.
Old Apr 14, 2007 | 04:34 PM
billofdurham's Avatar
Default RE: temperature sensor
If the temp sensor is faulty it will send wrong informationto the control module and thatcould affect mpg. It is located on the left side of the engine on the intake manifold.
Other sensors - ABS front; ABS rear; Airflow meter; Brake fluid level; Bulb failure; EGR Temperature; Impulse sensor (RPM/TDC); Knock sensor; Speedometer sensor; SRS Crash sensor and Throttle position sensor.
Your car is fitted with a diagnostic unit in the engine compartment. With this you can check fuel and ignition systems for problems. This includes the temp sensor.
For a full how-to:
http://www.matthewsvolvosite.com/cha...c&start=12
Scroll down till you find it. It is headed 740 but applies to 240, 740, and 940.
Old Apr 15, 2007 | 09:33 AM
AAER's Avatar
THANKS FOR THE INFO....ALSO WHAT DO YOU THINK OF THOSE ENGINE FRICTION ADDITIVES FOR OIL? SHOULD I TRY THIS?
Old Apr 15, 2007 | 03:38 PM
The official Volvo line is 'do not use oil additives'. My opinion is with a car that age and possibly high miles go for it.
I prefer the Molyslip brand as opposed to those that are supposed to stay in the engine even when you do an oil change. I could never work that one out - how does it know to stay there when all the oil goes?
March_Hare
Oct 17, 2013 09:37 AM
andysvolvo
Sep 10, 2012 07:52 AM
deathbots
Dec 27, 2007 09:08 AM
missgwen
Jul 11, 2007 05:45 PM
