1993 volvom 940 wagon turbo headlights
Old Apr 3, 2015 | 06:35 PM
HECTORPORTALUPPI's Avatar
Unhappy 1993 volvom 940 wagon turbo headlights
Hi!
The two headlights on my wagon sop working!
What could it be?
Light bulbs burn out?
Fuses?
Relays?
Thank you.
Hector.
Old Apr 3, 2015 | 06:49 PM
have you checked the bulbs ?
the 4 headlight filaments are wired to fuses 17,18,19,20 in the main fuse panel behind the ashtray.
do the high beams flash if you hold the high/low switch in intermittent flash mode? that goes through fuse 2 and bypasses the headlight relay (whihc is relay "K" in the main fuse panel).
jws
Dec 30, 2011 08:09 PM
VDriver24093
Feb 21, 2011 04:35 PM
S5990
Sep 23, 2009 11:03 AM
pisque
Aug 11, 2006 09:00 PM
blackbeauty
Jun 20, 2006 11:43 PM
