1994 940 motor shuts off above 2000 RPM
Old Aug 13, 2009 | 11:15 PM
seattlego's Avatar
Red face 1994 940 motor shuts off above 2000 RPM
My 1994 940 non-turbo has issue with stalling problem.
It stalled on the way work couple weeks ago.
Be able to restart the car but it stalls again when I hit the gas pedal.
Drove it back home with idle only speed.
I thought it has clogged Fuel filter so I replaced it. But it still has same problem.
Idles fine till around 2000 rpm but it cuts off or really shaky and dies above 2000 rpm.
What should I do it next?
Thanks in advance.
It has recent Plugs, Cap and Rotor. Cleaned TB, IAC and PCV.
Old Aug 14, 2009 | 12:55 AM
blue goose's Avatar
It sounds like a vacuum leak or fuel pressure regulator (FPR). Pull the vacuum hose off the FPR and sniff for gas. Did you have the symptoms before the TB was cleaned?
Old Aug 14, 2009 | 09:30 AM
fcpgroton's Avatar
Former Sponsor
+1, on a vacuum leak. Or there is a sensor that is shorting out.
Old Aug 15, 2009 | 02:10 AM
seattlego's Avatar
Got back home late from baseball game tonight.
I checked vacuum leak and sniffed vacuum hose off from FPR it seems like normal.
I did not have symptoms before the TB was cleaned.
While I checked around for vacuum leaks, I found that RPM sensor cable is peeling off right above the bell housing. So jiggled the cable little bit and fired up the motor.
It runs fine. Amaging!
My next question is that RPM sensor makes the car stalls and shaky?
Thanks again.
Old Aug 16, 2009 | 08:34 PM
hovonogila's Avatar
This problem you've described would most definitely point to a failed or failing crank position sensor....the one in the bell housing. This part will cause the car to stall and perform poorly, and most likely strand you. If it's the original it is way past its intended service life. FCP has them for about $35....Bougicord OEM. Buy one and put it in right away....that's your culprit!
Old Aug 17, 2009 | 10:33 AM
seattlego's Avatar
Thanks hovonnogila!
I'm going to order a RPM sensor from FCP.
I post another thread for IAC and ECU problems.
Could you please take a look at that.
Thanks again.
HECTORPORTALUPPI
Aug 18, 2011 05:28 PM
HECTORPORTALUPPI
Aug 18, 2011 01:23 PM
rzreese
May 24, 2011 08:31 PM
hickdead
Aug 9, 2009 02:12 PM
awecomms
Jan 1, 2009 03:49 AM
