HELP No RPM's above the 1 on the gague when I press the gas
Old May 22, 2011 | 09:57 AM
rzreese's Avatar
Unhappy HELP No RPM's above the 1 on the gague when I press the gas
Help! Yesterday I replaced my fuel filter because I thought if was clogged. After doing so, the car ran fine all day. This morning, I went out and started the car, but when I pressed the gas, no RPM's above the 1 on the gague. Car didn't stall, engine continued to run, however the rpm needel fluctuated a bit but wouldn't catch. No acceleration what so ever. Any ideas?
Old May 24, 2011 | 08:31 PM
Carrots's Avatar
Check your fuses and see if the "throttle" fuse is blown. If so, change it. If not, see what codes are set. Is your car a 99-01 model? If so, you may be looking at a new ETM, which is pretty expensive. I recommend xeMODex's rebuilt ETMs- they permanently fix the problem and are a lot cheaper than going through Volvo. Don't go changing the ETM without getting some sort of confirmation that that's what it is... but that's what it sounds like to me, if that fuse isn't blown.
VTs70GLT
1998-2000 model year V70
Jan 13, 2014 05:22 PM
AndyXC70
2001-2013 model year XC70
Jun 18, 2012 08:14 PM
seattlego
Aug 17, 2009 10:33 AM
awecomms
Jan 1, 2009 03:49 AM
IanCompetent
Jan 15, 2007 08:40 PM
