1994 Volvo 940 Cranks but will not start
Old Jan 2, 2015 | 09:16 PM
AlexMacDonald's Avatar
Default 1994 Volvo 940 Cranks but will not start
Hi, I have a '94 940 non-turbo that will turn over but not start. The car has worked great as of recently when the temperature was quite cold, -20. My 940 has fairly new spark plugs, and also a fuel pump. This same problem occurred last winter, and turned out to be the camshaft sensor. This sensor was replaced at the time and has had no issues until now. The fuel pump relay is working, as I checked it, but I am stuck to find a solution. Tried boosting it and still, no luck. Any advice is appreciated.
Old Jan 3, 2015 | 12:48 AM
you need to determine if its fuel or spark ... engine needs both to run.
Old Feb 4, 2023 | 10:31 PM
Zak's Avatar
Zak
well it has spark that's for sure I checked coils, distributor and sparkplugs all good so what would I check for fuel ?
DarthVolvo2003
Oct 23, 2022 10:04 AM
HECTORPORTALUPPI
Apr 6, 2014 02:04 PM
oilman940
North East
Nov 13, 2012 09:20 PM
HECTORPORTALUPPI
Feb 27, 2011 04:41 PM
pitttl
Nov 15, 2005 10:23 AM
