1994 Volvo 940 Replacement Engine Options
Old Nov 1, 2016 | 02:32 AM
Fitlab's Avatar
Unhappy 1994 Volvo 940 Replacement Engine Options
I am searching for a replacement engine for my beloved 1994 2.3 Volvo 940 Polar and would like some advice on what engines are compatible.
Any advice happily received :]
Thanks in advance,
Andrew.
Old Nov 2, 2016 | 01:01 AM
the engine block and head and stuff from any 940 2.3 should be directly compatible. non-turbo if your polar is non-turbo. you could probably adapt a 240 or 740 non-turbo 2.3L, too (the 240 has a side mount distributor, so you'd need to cap that off, and use your 940's rear-of-the-head distributor after removing the plug/cap from the 240 motor).
saying 'polar', I'm guessing you're not in the USA, as I don't believe that name was ever used here.... Please, add your general location to your profile or mention it in your posts, as there's a fair number of little differences in different country versions of these cars.
d_brass's_volvo
May 3, 2011 09:15 PM
ibified
Oct 21, 2010 04:36 PM
tjohnson05
Sep 17, 2009 10:23 AM
Mchammer9111
Sep 9, 2009 02:57 AM
hickdead
Aug 9, 2009 02:12 PM
