1995 Volvo 940
Old Mar 1, 2006 | 03:51 AM
tupapison's Avatar
Default 1995 Volvo 940
Hello
i posted this before and TECH answered my doubt, about the problem i had which is that whenever i start the car the RPM goes below the 900 RPM standard i believe and it shuts off, i took it to the mechanic and i told the guy clean the IDLE engine and the throttle body, and he "said" he did it, but i dont believe him, maybe he did and that didnt fix it?
Old Mar 1, 2006 | 04:27 AM
pznuttz's Avatar
Default RE: 940 starting issue
have you checked the plugs, wires, dist. cap or rotor button
Old Mar 1, 2006 | 01:19 PM
tupapison's Avatar
since i take it to a mechanic, he "checks" all of that, but how can i be sure...maybe if i take it to the volvo dealership?
Old Mar 1, 2006 | 08:43 PM
ORIGINAL: tupapison
Pull the hose off the throttle body and look inside with a Mirror.
Old Mar 1, 2006 | 09:38 PM
tupapison's Avatar
oh ok, would you provide a pic of what a throttle body looks like? and another question, is the distance that you have done on a volvo on kilometers or miles?
Old Mar 1, 2006 | 09:59 PM
Sorry I don't have any pics. Look for a hose going to the engine on the left side of the car. The peice it attaches to on the engine is the throttle body. You can also folow the Cable to the engine and then the little Rod that goes to the throttle body as well.
I don't Own a Volvo but have seen many of them with well over 300,000 miles on them.
Old Mar 1, 2006 | 10:32 PM
tupapison's Avatar
oh ok, and if i check it and its dirty, how can i clean it?
tupapison's Avatar
so the distance on my odometer is on miles?
Old Mar 1, 2006 | 10:41 PM
First buy a new gasket. Then remove it and clean it with Carb cleaner. Then reinstall it.
Old Mar 1, 2006 | 10:56 PM
tupapison's Avatar
wait i didnt understand, so if its dirty, i should buy a new gasket, clean out the throttle body and then reinstall it with the new gasket?
will this carb cleaner work? http://www.amazon.com/gp/product/B00...nce&n=15684181
Old Mar 2, 2006 | 01:00 AM
Yes if it is dirty that is what you need to do.
Yes the Carb cleaner will work as well.
If you decide to tackle it and it is dirty the let me know when you do it.
I will try my best to walk you through checking the throttle switch and plate adjustment.
Old Mar 2, 2006 | 01:28 AM
tupapison's Avatar
i think i will take it to the mechanic and guide him through it because i dont really think i will do it
and if its dirty, will the mechanic know how to clean it? (he's not very competent) i think i will take it to the volvo dealership
Old Mar 2, 2006 | 01:57 AM
Thats up to you. It really isn't all that hard. Would probably take you 45min to an hour for your first time.
All you will need is a straight screwdriver,13mm wrench and maybe a 8mm wrench and possibly allenwrenches.
Old Mar 2, 2006 | 02:51 AM
tupapison's Avatar
Ok, i will try to do it, and i will be taking my car for a engine wash because its DIRTY, look at it and then maybe you see what 11 years of not cleaning it looks like heh, also on the back seats of the car, what do you call the thing where you put items like behind the drivers seat and the passengers seat? because the elastic that goes there is all worned out, and i want a new one
Old Mar 2, 2006 | 08:27 PM
I call them Seat Pockets. But they are part of the seat cover and you have to buy the seat cover for like $300.00 to $400.00 each.
Old Mar 3, 2006 | 12:36 PM
tupapison's Avatar
oh my lord, i cant just change the elastic band in it? !! oh well, ill see what i can do, and also i just changed the 4 shock absorbers of my volvo, and the car feels exactly the same way it did with the old shocks, i mean i feel every hole on the street, maybe because the shocks are brand new and they need time to loosen up? whats wrong?
Old Mar 3, 2006 | 09:21 PM
  #17
What is the tire pressure at?
Old Mar 5, 2006 | 04:25 PM
  #18
tupapison's Avatar
At 30
and also the top speed the car will go is 140KM....Why is this? is this the top speed the car can reach? or something is dirty or what?
Old Mar 5, 2006 | 05:27 PM
  #19
Possibly the springs are worn.
It should go faster than that. Not to sure why though.
I wish I was there to look at it.
Old Mar 5, 2006 | 05:34 PM
  #20
tupapison's Avatar
oh ok, but what? springs are worn? which ones? because the shock absorbers are brand new
