1995 Volvo 940
Old Mar 18, 2006 | 11:44 AM
  #81
Default RE: 940 starting issue
Those look Cool make sure the Offset is proper.
Old Mar 18, 2006 | 03:14 PM
  #82
tupapison's Avatar
yeah i asked the guy about that and he said that the offset was something like.....40? i cant remember, do you know what is the offset for this car?
Old Mar 19, 2006 | 08:30 PM
  #83
Not right off hand but will check.
Old Mar 20, 2006 | 12:15 AM
  #84
tupapison's Avatar
and about the interior color of the car, there wasnt any 4 digit code like you said, more like 5 and up
Old Mar 20, 2006 | 08:27 PM
  #85
There should be a 4 digit codes on the metal plate under the hood. The 5 digit should be the Paint Code.
Old Mar 20, 2006 | 08:48 PM
  #86
tupapison's Avatar
yeah i looked there under the hood, and there are only 5 digits and up
Old Mar 20, 2006 | 09:45 PM
  #87
HUMMMMM there should be one set with 4.
Unless yours is to old.
Maybe call the Dealer and Ask for a price for the visior and when they ask for the color code ask how to find it.
Old Mar 20, 2006 | 10:42 PM
  #88
tupapison's Avatar
yeah i can do that, but if cars older than mine it has it, mine must have it
Old Mar 20, 2006 | 11:01 PM
  #89
Yes but I mean it might be a 5 digit code.
Old Mar 20, 2006 | 11:38 PM
  #90
tupapison's Avatar
oh ok, ill check, thanks
i attached a picture of the metal plate, a little blurry but you can see it
Old Mar 24, 2006 | 04:28 AM
  #91
tupapison's Avatar
ALSO im having a HUGE problem with my gas! TECH HELP ME, i filled up my car on wednesday at 4 PM, and it was over the full line thingy,and today march 24th(1 day after) at 1 AM, i have more like 3/4....whats wrong!? look at the pics and help me please, i have driven 64KM, so its normal?
Old Mar 24, 2006 | 09:04 PM
  #92
Maybe the Guage is messing up.
Do you Beat on the car?
Do you smell gas outside in the back of the car?
Old Mar 24, 2006 | 09:12 PM
  #93
tupapison's Avatar
Hello, sorry but what is the Guage? also, what do you mean if i beat on the car? if i step on it? if you do mean that, no i drive like always, but i mean, i have driven 70 KM in 1 day :S......and also no i dont smell gas
Old Mar 24, 2006 | 09:55 PM
  #94
Sorry I actually meant to say the sending unit in the tank for the guage.
They are known to mess up from time to time. Watch it and see what happens in the next couple of tanks of gas.
Ok just checking. I always BEAT my cars. I always go fast.
Old Mar 24, 2006 | 10:28 PM
  #95
tupapison's Avatar
how can i explain to my technician to check if that gauge is messed up? because i dont smell gas at all
Old Mar 24, 2006 | 11:08 PM
  #96
Some Tech's have a tool to measure the resistance from the sending unit to see if it is reading.
If not you will need to replace it.
But like I said try another tank or 2 and see what happens.
Old Mar 25, 2006 | 02:48 AM
  #97
tupapison's Avatar
Ok, i will try to do that, but i will take the car to the mechanic tomorrow for him to measure that, what he need to check is the Fuel Level Sending Unit? also i just checked and i do not smell gas.......also whats a fuel pump relay for?
Old Mar 25, 2006 | 11:22 AM
  #98
Sometimes you can use a meter to test it. But other times you need a special tool to do it.
The fuel pump relay only controls the pump itself.If the relay was going bad the car would stall at times or just not start.
Old Mar 25, 2006 | 03:31 PM
  #99
tupapison's Avatar
i asked the seller ofthe shift **** about the overdrive button and he said "The shift **** does not have the button with it. It does have the cutout so that the button can be installed though, so wil it work?
Old Mar 25, 2006 | 03:45 PM
  #100
If you are going to cut the hole then it should work fine.
