240 3rd brake light question..
Old Oct 11, 2016 | 05:09 PM
smshnick's Avatar
Question 240 3rd brake light question..
Hi all,
I just installed two of the new wiring harnesses for the rear hatch on my 240 wagon and the 3rd brake light is acting funny. It stays on when the brake pedal isn't depressed, and turns off (with the dash light coming on) when the brake pedal is released. Any thoughts on how to remedy this?
Old Oct 14, 2016 | 07:25 PM
smshnick's Avatar
Smile Any ideas?
Any thoughts on this one?
Old Oct 17, 2016 | 01:49 PM
that suggests somethings not connected properly. ensure the 3rd brakelight has a good ground. all 3 of the brake lights are on separate wires all the way from the 'bulb out sensor' under the dash.
Old Oct 22, 2016 | 01:11 AM
BCVolvo1990's Avatar
You replaced the entire harness in the hatch itself ? There are a few grounds in there ensure they are secure as well as connectors in hinges are correctly installed.
Old Oct 22, 2016 | 10:15 AM
smshnick's Avatar
The harnesses I installed are brand new, but I didn't do anything w the broken ground wired in the hinge..I guess I did t think they really did anything.. I will hook them up and give that a try!
Old Oct 22, 2016 | 08:07 PM
smshnick's Avatar
That did the trick! Thanks! So I assume, the reason why my power lock on the hatch doesn't work is because of the ground on the other hinge..
Old Oct 22, 2016 | 09:12 PM
All Grounds Matter !
Old Oct 23, 2016 | 01:29 AM
Glad to hear it worked out
iambowie
Oct 21, 2012 07:27 PM
jnduke
Oct 8, 2010 09:17 PM
andyandersson
Sep 22, 2010 09:25 PM
smartman
Sep 14, 2008 11:02 PM
Vlxx
Mar 30, 2007 11:44 PM
