240 blowing hot air on the cold setting
Old May 23, 2008 | 11:00 AM
micah360's Avatar
Default 240 blowing hot air on the cold setting
I have a 92, 240 that I bought when it was cold out last winter, so I've really only had to use the heater until the last few weeks. I've noticed now that when it's switched to the cold setting, it's still blowing hot. Although it's not as hot has the full heat setting, I know it's not as cool as it should be. But, when I click the AC on, it's gets cooler, but when the AC is turned back off, it's back to hot again.
Any ideas? Is this a thermostat replacement issue??
thanks...
Old May 23, 2008 | 01:56 PM
billofdurham's Avatar
Default RE: 240 blowing hot air on the cold setting
It sounds more like a stickycoolant valve ora badly adjusted cable to that valve. This is located on the left side of the AC/heater unit.
Old May 28, 2008 | 04:14 PM
micah360's Avatar
Thanks. I'll start ripping stuff apart![:@]
HarryO
Jul 15, 2023 03:58 PM
somethingsalty
Oct 10, 2009 05:57 PM
austeve
Jul 29, 2008 09:08 PM
beardo265
Sep 27, 2007 09:24 AM
