240 Brake line connections leaking
Hello,
I have been experiencing small leak from Brake lines.
Keep fixing, clean thread and re-tight connections but still leaks....
Should I use Teflon tape or any other material on thread to solve this problem?
Or any advices, please let me know.
Thank you!
TAT
Thank you!
TAT
you could try a small amount of pipe thread compound :RECTORSEAL Pipe Sealant,MultiPurpose,1.75ozTube,Ylw - Pipe Sealants - 4YRW3|25790 - Grainger Industrial Supply
Though, Brake fluid is likes to eat stuff. it may work its way through.
Thank you guys. I did one more time, loose-tight(really hard) those lines yesterday, now seems no leak at the moment. Cross finger.
I got lines from Junk yard and used it already
I was also thinking about sanding at the end, peel old brass and work with new surface. I didn't try out but maybe better than some other material which maybe melt by brake fluid.
