97 850R cranks, but will not start
Old Jan 23, 2006 | 11:58 AM
Ahhsk's Avatar
Default 97 850R cranks, but will not start
hey guys,
the car (wagon actually) has 127,000 miles on it. was running fine, then last week just didnt want to start.
while cranking it didnt appear to be sparking (no exhaust smoke, or attempted "catches"). tried the quickstart spray to see if it was sparking and perhapes a fuel problem, no change.
under the hood I noticed that the Idle Air/Speed Control Valve was humming, even with the key out. is that normal? could the Idle Air/Speed Control Valve prevent a start?
Any advice would be greatly appreciated.
thanks
Oscar
Old Jan 23, 2006 | 12:43 PM
S70driver's Avatar
Default RE: 97 850R cranks, but will not start
1. Check the alternator.
2. Check all lines to see if they are cracked, busted, etc... And reconnect them if they are disconnected.
3. Check the battery for how much power it is producing.
4. Check spark plugs, make sure none of them are wet.
5. Fualty wiring, causing a short somewhere.
6. Starter
Old Jan 23, 2006 | 03:57 PM
You might also want to check the cam sensor. It is located on the back of the cams. Looking from the left side of the car under the hood it is to the right of the Dist cap. Follow the wire from it and check the white plug. They are known to fall apart.
Old Jan 24, 2006 | 04:46 AM
Ahhsk's Avatar
what about the humming Idle Air/Speed Control Valve? could that cause it to not start. it even hums when I take the key out...
Ill go through the engine bay and check those items.
Thanks
Oscar
Old Jan 24, 2006 | 10:11 PM
It will normally run for a few seconds or so then shut off. No that would not keep it from running.
Old Jan 24, 2006 | 11:56 PM
Ahhsk's Avatar
ahh cool, cause that bad boy is like $200. im going to check the cam sensor, add some fresh gas with an anti ice additive, check fuel pressure, do a basic tune up, wires+plugs. and hopefully ill be on the road again by next week.
thanks again Tech, and others. ill keep you posted.
Oscar
Old Jan 25, 2006 | 12:15 AM
Glad we can help thats why we are here.
nightmarevolvo
Feb 4, 2023 06:20 PM
Baseball850
Jan 13, 2014 09:15 PM
Kipp
Jan 26, 2009 12:04 AM
2plus2=5
Nov 30, 2008 04:11 PM
mracr
Feb 14, 2007 12:53 PM
