240 DL
Old Oct 5, 2008 | 07:39 PM
kimkrava's Avatar
Default 240 DL
Help someone,
I have a 1986 volvo 240 dl. I went over some railroad tracks and it cut off. It sounds like it want to start but wont. Or it will start for 1 to 2 seconds then cuts off. I had a mechanic look at it. He tested the fuel pump and said pump fine. Ii there a fuel injection relay switch for a 240 dl volvo? If so where is it located. Please help a damsel in distress.
Old Oct 5, 2008 | 08:08 PM
blue goose's Avatar
Default RE: 240 DL
Check the fuel pump relay. Better yet, replace it if it's original. Passenger side interior, mounted on the firewall. Remove the fiber panel above the passenger's knees. It's a white relay, about 2" x 1.5", the only one there.
Old Oct 7, 2008 | 04:37 PM
wojeepster's Avatar
Default RE: 240 DL
check main fuel injection fuse on driver side inner fender 25 amps these sometimes blow.
insectintellect
Jul 5, 2012 01:49 PM
dman777
Aug 7, 2009 03:19 AM
bne
Apr 6, 2008 05:12 PM
maves75
Feb 3, 2008 04:56 AM
1985_240DL
Sep 20, 2006 08:20 PM
