240 Driver's door lock button slips, door sometimes stays locked - how to fix?
Old May 26, 2021 | 03:34 PM
  #21
dlbordessa's Avatar
Default Spring # 3
Originally Posted by Lgbpop
OK, update.
Pierce put me onto the solution. Cheers, brother - and thanks. Popping the RF door panel clarified things.
For starters, the spring belonged in a location I hadn't expected...but, once I found where it lurked, I was able to install the replacement inside the LF door with some illuminatory help from the wife. (That's fancy talk for her holding a flashlight.)
Briefly....there is an extension of the inside-half latch housing which turns 90° toward the front of the door, following the doorskin. Attached to that is a bell crank, in turn attached to which is the inside vertical lock-linkage rod. That stupid little 84¢ spring I bought fits between the stationary extension and the bell crank. Once I figured out where it went, it was a somewhat simple matter of spreading the bell crank and bracket apart a bit; then I used a Dremel tool to put a small slot into the blade of a jeweler's screwdriver, to push the loose spring end into the bell-crank hole after I had it anchored into the extension. After that, I just bent the bell crank back into place close to the bracket/housing extension and replaced the linkage-rod clip.
No more slop in the LF lock-linkage rod. It's tight as a virgin now, excuse the expression.
BTW, this fix does NOT require removing the latch halves from the door skin!
you seemed to have gotten a more detailed diagram for the placement of that spring. I have the same problem on my back passenger door. Could you share that information you got?
Thank you!
Diana Bordessa
87roadwarrior
Aug 26, 2015 10:26 PM
hunterw0026
Mar 21, 2011 09:49 AM
x-angel
Nov 11, 2010 08:48 AM
dennis5452
Jul 12, 2010 07:09 PM
850R Dave
Dec 16, 2009 09:41 AM
