240 GL idle problem 1984
Old Mar 30, 2008 | 05:52 PM
champ's Avatar
Default 240 GL idle problem 1984
New Member Help!?
I have an older 240 1984 Sedan but in good condition
with 180,000.
Recently when I start the car (it starts easily) the car
runs rough when idleing. However when I do up to
any speed it runs fine. It kind of hiccups alittle and
the engine just feels like it is limbing along. I have done
the below>
1. Checked cylinder compression all good
2. Clean all sparkplugs and wires and checked all good
3. Clean rotor and distributer and checked wires all good
I think it is a timing problem that occurs in idle
Any suggestions> could it be my timing belt?
Old Mar 30, 2008 | 09:55 PM
blue goose's Avatar
Default RE: 240 GL idle problem 1984
It sounds like it could be a sticking idle air control valve (idle motor), IAC. Check to see if it's dirty. They tend to get crudded up after a few years. It bypasses the throttle and it's purpose is to supply intake air when the throttle is closed (idle).
Old Mar 31, 2008 | 08:16 AM
jonesg's Avatar
Check throttle body for crud around/under butterfly too.
Carb cleaner and a toothbrush helps.
Maybe time for a complete tuneup.
brettmhatch
Mar 21, 2011 08:34 PM
dgoodhue
Apr 12, 2010 10:16 PM
Earwig225
Dec 12, 2008 06:21 PM
mikeheraly
May 30, 2008 04:47 PM
wahhman
Mar 11, 2008 09:36 AM
