1984 240 DL Transmission Problem
Old Mar 10, 2008 | 06:09 PM
wahhman's Avatar
Default 1984 240 DL Transmission Problem
Hello,
I am not a car guy at all and just need some help with my 1984 240 DL. I got in my car this morning after starting it and backed out of my driveway in reverse which was not a problem. Well I get out to the street and put it into Drive and nothing, rev it a little and it would engage, well I got half way down the block and turned around. IT will not catch from gear to gear (automatic), it was even having trouble finding reverse the second time. I am on a tight budget so any advise as to what it might be would be greatly appreciated. At first I thought it was the cold, about 25 here in Minnesota.
Thank you
Old Mar 10, 2008 | 07:17 PM
jonesg's Avatar
Default RE: 1984 240 DL Transmission Problem
I'd check the fluid, be aware its cold , theres 2 sets of marks, one for cold and one for hot, if its close its fine.
Check the linkage, they become sloppy when the nylon bushings wear out, mine are missing.!
Wear warm clothes, jack car up, use jackstands.
Get under and follow the linkage,
Buy a Haynes manual, get some silcone gloves and hand cleaner from the auto part store and try moving the linkage around,
its greasy down there.
If everything seems ok, let the caridle until its warm, the tranny fluid pumps through the radiator and it might warm it up a bit, see what happens.
This photo shows the linkage rod hanging down, the tranny is being dropped for repair.
http://cleanflametrap.com/RearMainSe...0helping02.jpg
Heres a diagram
http://www.brickboard.com/FAQ/700-90...ifter_Is_Loose
Read the FAQ file, it includes troubleshooting.
http://www.brickboard.com/FAQ/700-90...issionAuto.htm
Old Mar 11, 2008 | 09:36 AM
tedv's Avatar
You need a new tranny...
Spyros
Jun 13, 2012 11:43 AM
LC Garage
Aug 24, 2011 01:48 PM
brettmhatch
Mar 21, 2011 08:34 PM
mikeheraly
May 30, 2008 04:47 PM
champ
Mar 31, 2008 08:16 AM
