240 Odd Overheating
#21
well that is a ghetto fix that I personally would never do, but you can do whatever you want on your own car. That makes a weak point that WILL fail sooner or later. Whether you are the owner still when that happens...
At least the driver will just loose fluid to the point where the tranny will slip and operator will then be stuck on the side of the road instead of having a blown trans.
So did you ever get "steam" again? How is your fan doin'? ; )
#22
I ran a line like that for several months without issue until I could find a JY replacement. You can also use a 5/16" compression fitting for a more secure/ heat resistant fix especially if the area is near the exhaust.
#24
It won't. There are just some sections that are close to the exhaust- which might be fine. Long term, though, I'd do a compression fitting or line replacement. Just so it's out of mind.
dex_sinister
07-11-2007 03:03 AM
