1995 940 transmission linkage.
Old Jun 28, 2015 | 12:48 PM
WJames's Avatar
Default 1995 940 transmission linkage.
A little help please before dropping transmission. 1995 940. Shifter suddenly got sloppy. Found worn bushing at linkage on transmission. Replaced bushing. When tightening back on, gave an extra snug and linkage turn a partial rotation. Unable to get it out of Park before or after re-assembly of shifter. Suggestions to unlock it before dropping tranny and bringing it in??
Old Jun 28, 2015 | 01:49 PM
lev's Avatar
lev
Kind of hard to visualize what you did... May be a photo?
Old Jun 28, 2015 | 02:13 PM
WJames's Avatar
Replaced parts at linkage. While tightening it kicked to the right about 15-20 degrees. It won't go back and is locked in park. Does this help?
Old Jun 28, 2015 | 02:32 PM
WJames's Avatar
That didn't work. How about this.
https://www.volvoclub.org.uk/faq/Ima...terBushing.gif https://www.volvoclub.org.uk/faq/Ima...terBushing.gif
Linkage on tranny was at 12:00. Upon tightening it clicked to the right about 1:30. It won't come back. Right now it's raing and car is on the ground.
Old Jun 28, 2015 | 02:46 PM
WJames's Avatar
And I can't get a diagram to post.
Old Jun 28, 2015 | 03:52 PM
REVOLV's Avatar
Drop the tranny.
Old Jun 28, 2015 | 03:59 PM
WJames's Avatar
I was hoping for something a little more optimistic. But (sigh), I had a sneaking suspicion that would be the case. Should've reconnected all the linkage before tightening that bolt. Thanks, long day tomorrow now.
Old Jun 28, 2015 | 04:15 PM
REVOLV's Avatar
I hope you didn't just go run outside and drop the gearbox. I was being a jerk and being sarcastic.
Did you loosen ANY nuts back on the end of the shift linkage when you did the bushings? If so, you did it wrong and probably have misadjusted linkage now. You only are supposed to use a pick and pull off the clips for a bushing change!
Old Jun 28, 2015 | 04:25 PM
WJames's Avatar
Took linkage down to and from shifter. Silly, I know. Can't take it back. Going to try pulling console and crossing wires on that silly switch I've been reading about. If that doesn't work, I guess tranny comes out. Just don't understand why it won't just click back to re-install linkage in original position.
Old Jun 28, 2015 | 04:40 PM
REVOLV's Avatar
slow down dude!
Oh yeah, forgot about the Shiftlock mechanism. Do you hear solenoid click when you hit the brake pedal? Crossing wires!!!!? WTF?
If the solenoid aint workin', there is a yellow shift lock override tab/button somewhere down there. I forget. See if you can get the shifter outta park using that! dont go crossing wires!
Old Jun 28, 2015 | 04:57 PM
WJames's Avatar
I will look for that. More than a little certain it isn't solenoid. But I also can't stop thinking I should have disconnected battery, but didn't. I see a lot of people go through the shift lock switches.
Old Jun 28, 2015 | 05:23 PM
REVOLV's Avatar
Well its as simple as listening for the click when you hit the brake pedal. If you dont hear it, you check IF you have 12v making it all the way to the solenoid positive wire or not. If you do, solenoid is bad. If you don't, wiring is bad. That simple.
Please don't go crossing wires. There are fuses in the system to prevent massive wiring meltage due to the event of a short circuit. Don't introduce your own short circuit just because you don't know what you are doing.
Old Jun 28, 2015 | 05:26 PM
REVOLV's Avatar
If you don't have a multimeter, you could just connect the solenoid positive wire to the ground wire, aka "cross" the wires, and then step on the brake pedal and listen for the fuse to pop. If you pop the fuse, your wires are workin'! hahaha
Old Jun 28, 2015 | 05:35 PM
WJames's Avatar
Thanks, that's for tomorrow when it stops raining. Fuses are cheap. Lol. But I have a multimeter
Old Jun 29, 2015 | 12:44 AM
REVOLV's Avatar
Multimeter!!!
DCampion
Jul 16, 2012 06:48 AM
dirt
May 23, 2010 04:17 PM
tank940
Mar 9, 2010 08:21 AM
squid
May 27, 2008 03:18 PM
jonmouse
Nov 7, 2005 10:50 PM
