240 questions!
Old Mar 9, 2012 | 03:36 PM
xdunaticx's Avatar
Default 240 questions!
Okay, so I just recently got a good deal on this 240.
first off, there is no dash lights at all! I'm thinking it might be a dimmer switch.
Another issue is the over drive isn't working and it's straining on the freeway.
If anyone can give me some advice that'd be great
Old Mar 9, 2012 | 09:22 PM
Burn Stains's Avatar
Welcome to the forum, a good deal you say? Then you must have paid only $50 dollars.
Overdrive = Very common problem, so start here https://volvoforums.com/forum/volvo-...ngaging-34724/
As for your dash lights, are the bulbs good? Do any of the lights work for the ambient illumination of the switches? If automatic, does the gear selector have an illuminated gear selection? It could be a fuse, and could be the rheostat as those do fail. Is one of your parking lights out as well?
Old Mar 10, 2012 | 01:16 AM
xdunaticx's Avatar
yea my turn signals work, and my bottom lights but there is no lights for the speedo, nor does the trip counter work
Old Mar 11, 2012 | 11:21 AM
tonyvolvoluvr's Avatar
Hi. I am new to this site. I'm not sure how to navigate. I have a 1991 Volvo 240. I need to replace the ignition switch. Does anyone know the easiest way to get the two screws out after the wiring harness is removed from the back of the switch? Is there a certain screwdriver or what? Thanks.
Phil 850
Jul 25, 2012 10:01 PM
AnEskimo
Sep 25, 2010 08:32 AM
repeatclicks
Mar 12, 2006 09:09 AM
SLOPOKE
Apr 8, 2005 08:38 PM
jdbs3
Jan 29, 2005 12:21 AM
