240 shift light and blown bulb light
the shift light is connected to a relay-like control module, this control module takes input from the tachometer, speedometer, and a switch on the clutch pedal, it lights when it thinks the RPMs are too high for the speed. I believe its under the dash to the far left
the bulb failure sensor is a round module that compares the current to the left and right bulbs of each pair. any differences in the current can trigger it. corroded sockets and/or wiring connections, mismatched bulbs can trigger it. You should always use tail light bulbs that have chrome not brass bases, in American car parts stores, these are often on green Sylvania brand 'hang cards' that say OEM. I always replace the left and right bulbs of any given pair together to forestall such issues. This bulb failure sensor is under the dash, left of the steering wheel, mounted horizontally.
Yes that's the bulb out relay
For the bulb out - figure out which bulbs are turning the failure lamp on.
The relay cares about - the 4 rear parking lights - two on each side, commonly the outer bulb holders/housing/circuit board melts/gets a bad connection and cause either brake bulb or parking light connection problems.
It cares about the 3 brake lights, and the low beam headlamps.
So does it come on with parking lights? (all 4 working? ) With brake lights? (all three working?) or with low beam headlamps? If it's on all the time with the lights (and not when braking with the lights off) - it has to be either the headlamps or the rear parking lamps.
For melted brake/parking light problems - move the brake lamp to the rear fog lamp position - the upper inner lens - simply move the brake light wire in the connector at the tail lamps.
As other have mentioned the bulbs must use the same current - so the same brand would be best and the brass base made in china bulbs are usually of poor quality.
For the upshift light - take the bulb out!
https://www.prancingmoose.com/volvor...bfailuresensor
I believe it also compares the left and right front parking lights.
if you turn on just the parking lights, does the bulb out light come on ? then the problem is in the parking lights. if it only comes on with the headligths, then its in the low beams (high beams aren't checked). and if it only comes on when you step on the brakes, then its the 3 brake lights.
upshift relay location (171 on this drawing)
https://www.davebarton.com/pdf/relay_87_240.pdf
and what it looks like,
https://www.ebay.com/itm/Volvo-240-7...-/362968610041
ah this post has the wiring diagram for it. its from a 1985, but AFAIK, a 1988 should be exactly the same.
https://volvoforums.com/forum/volvo-...09/#post461789
The only Volvo I've seen that cares about the front parking lights is the 08+ v/xc70. Perhaps the s80 also with the same headlamp assembly. And they are a pain to replace, takes 3 hands. 240/260/740/760/940/960/01-07s60/xc v70/s80 - the front parking bulbs are not part of the bulb out system - but most are still fused left and right - meaning the left front and rear parking bulbs are on the same fuse, but only the wiring for the rear goes to the bulb out relay.
