240 starts rough in the morning or when its cold
Old Jul 28, 2009 | 01:55 PM
prophet_of_profit's Avatar
Default 240 starts rough in the morning or when its cold
I recently bought a 1987 volvo 240 wagon and I love it so far. It starts up really easy when its warm or when its warm outside, but when I start it in the morning, it starts easy, but then turns off. When i start it the second time, it usually stays on. If i pump the gas pedal twice before starting it, it usually stays started. Does anyone know what could be causing this? I would like to fix it so it stays started first try in the mornings? Thank you
Old Jul 28, 2009 | 05:36 PM
850dude's Avatar
Question
I'm having a similar problem on my 5spd '93 850. Not as severe though. On chilly mornings in Tampa ( < ~70 degrees), it will almost stall out if I stop within maybe 3 or 4 minutes when the engine's cold. The RPM drops and then picks back up a couple of times, but it's fine after that.
I also have a problem that might be related, where the acceleration isn't consistent, and the car jerks forwards a few times if I give it any gas.
Please let me know if you find out what the trouble could be.
Old Jul 29, 2009 | 09:14 AM
bubba240's Avatar
Its possible the idle air control valve is sticking and needs to be cleaned. You can remove one of the air lines and use a q-tip soaked with carb cleaner on the "flapper".
I would also measure the resistance of the coolant temp sensor - at 70 deg. F it will be around ~2.5K ohms. Its a blue wire (#2) at the ECU.
Look for any vaccum leaks.
tronnie
Sep 28, 2013 03:45 PM
04XC90T6AWD
May 16, 2011 06:08 AM
coolson
Dec 10, 2010 12:35 PM
KatieK
Nov 11, 2010 10:29 PM
bobkeenan
Jun 7, 2007 09:25 PM
