Check engine light on and rough starting in morning
Old Jan 27, 2008 | 03:02 PM
tronnie's Avatar
Default Check engine light on and rough starting in morning
Hi , new here but this is great to have this forum. Anybody having this problem, my 1998 v70 turbo is a little bit difficult to start in most cold mornings. Check engine light is on and our mechanic says there is nothing wrong with the car the last time it was in for abs module. Told me not to worry its fine but I do not like it on. Also the cooling fan is running after it is just started , could be normal but my wife drives the car more then me. Thanks
Ron
Old Jan 27, 2008 | 05:29 PM
Default RE: Check engine light on and rough starting in morning
What is the codes in the computer?
Might be a bad coolant temp sensor.
Old Jan 28, 2008 | 09:25 AM
tronnie's Avatar
Wow, I forgot to mention that my wife also complains it takes a while for the heat to warm up .
That makes a lot of sense what you just wrote...."temp sensor", I'll get the codes first but your good!
Thank you!
Ron
Old Jan 28, 2008 | 10:40 AM
JimKW's Avatar
He's not just good, he's the best.
Replacing the thermostat and coolant temp sensor is fairly easy and not expensive at all. Definitely a diy job for anybody who can just turn a wrench. The torx screws holding the housing on is the only tough part. As long as you don't strip them, you will be fine.
Old Mar 21, 2010 | 12:05 PM
volvolini's Avatar
Where is the coolant temp sensor located? We have p0117 code.
thanks!
Old Sep 22, 2011 | 05:48 AM
Bump...
Old Sep 28, 2013 | 03:45 PM
bryan.pedigo's Avatar
Is on the bottom of the Temp housing. I had a p0117 code and replaced the sensor, i noticed something was wrong when my fans were always on and continued to stay on for awhile after i turned the car off. although i just noticed the problem again and got the same code, but i didn't change my thermostat will do that next. I am also noticing slow throttle response when cold and also it has left me in the road dead a few times now as well. wonder if its all the same issues.
olvida
Jun 23, 2013 10:47 AM
lionhearted1
May 25, 2013 08:46 PM
prophet_of_profit
Jul 29, 2009 09:14 AM
ariston
Jun 29, 2008 12:24 PM
bobkeenan
Jun 7, 2007 09:25 PM
