240 Timing Belt advice
Old Sep 26, 2006 | 01:34 AM
daver80's Avatar
Default 240 Timing Belt advice
'89 240 wagon, just bought it, 200k, beautiful- Timing belt has been changed, but according to service records, it's been a long time. I should replace timing belt, cam oil seal, probably waterpump. I've done a lot of significant repairs on my Honda Civic, (I have put a clutch in a Civic before. no picnic.) MG, Beemer bike, tractor, never worked on a Volvo before. How tough is doing a timing belt, special tools, etc. chance of really screwing up things etc... THANKS!!! Dave
Old Sep 26, 2006 | 08:32 PM
Default RE: 240 Timing Belt advice
It is cake follow the link for basics.
Also you will need a crank tool unless you have air tools second link is to make special tools.
http://www.babcox.com/editorial/ic/ic60326.htm
http://www.volvoclub.org.uk/faq/Spec...rankHolderTool
Old Sep 27, 2006 | 11:47 AM
daver80's Avatar
tech- thanks for the link. How does a camshaft oilseal figure into the process?
Old Sep 27, 2006 | 08:44 PM
Once the belt is off you will need to remove the pulleys to get the old seals out.
bulldog80
Mar 28, 2011 11:15 PM
kstt
Oct 13, 2010 08:40 PM
kags1969
Jun 24, 2010 03:24 PM
Sambar Stag
Aug 15, 2009 03:17 AM
scubblicious
Jan 16, 2009 09:16 AM
