240 wanting to cut out!
Old Jun 30, 2009 | 09:28 PM
Somthngfrce's Avatar
Default 240 wanting to cut out!
Ok....So on my 240 everyonce in a BLUE moon I go to step on the clutch to come to neutral at a light or stop sign or to change gears and it feels like it wants to cut out on me. Seems a little odd. I think it has happened maybe 3 times since I have been driving it. What gives? Someone told me to adjust the clutch cable. I know it's hard to diagnose this just by description, but anyone have any insight? Thanks!
Old Jun 30, 2009 | 10:10 PM
Likely the throttle body is sticking. When you stop it goes into idle mode and if the throttle body is gummed up it will almost stall. I use to have to clean the tb on my 740 every 10k. I used carb cleaner and never replace the paper gasket.
Another possibility could be that you have a hole in the big intake tube. They usually open where you can't see them like underneath. You may be albe to feel it but it's best to take it off and inspect it.
benschumacher
Aug 13, 2010 02:43 PM
swedspeeder
Jul 2, 2009 12:12 AM
paul9038
Aug 16, 2007 09:00 AM
drivet5
Nov 10, 2006 05:19 PM
Volvo240guy
Oct 17, 2006 11:52 PM
