89 volvo gl 240, intermittent no crank
Old Mar 23, 2022 | 08:12 PM
Thatcountryboy's Avatar
Default 89 volvo gl 240, intermittent no crank
Alright guys I need some help, just acquired a wonderful running 240. It slowly developed an issue when you go to start it, turn the key and nothing happens. I would put it in neutral and it would start. That was what I would do for a few weeks until that no longer worked. Then I could only start it by jumping the starter with a screw driver. Occasionally it would start in park in neutral and back and forth. I got fed up and bought a new neutral safety switch, a new ignition switch, put those in place and it started fine. It would have an occasional hiccup while turning the key to start it would turn over and stop, I would let off the key and turn again and it would fire right up. It would do this every now and again which I didn't mind. Now I'm back to it only starting while jumping the starter. I need help. I cleaned the connections at the ground strap from the fire wall to the engine block, starter connections LOOK fine I would wiggle connections to try to start it to no avail, new igntion switch, new park neutral switch. I dont know where else to look. I'm mechanically inclined but not electrical. Could it be the starter it self?
Old Mar 23, 2022 | 08:54 PM
silvermine's Avatar
just because the connection of the red wire at the starter end may look ok it would be prudent to take it off clean and reconnect it just to see if
anything is different.
Old Mar 23, 2022 | 09:39 PM
Have you used your $3 12v test light to check for power at the small solenoid wire when it won't start? That might be a good step, use a tool (that would be useful for all sorts of other things) and test for power. If no power there then backtrack to the Neutral starter switch - then to the ignition switch. Or start at the ignition switch and work the other direction.
Old Mar 24, 2022 | 05:01 PM
When I get to work tomorrow and put the car on the lift I will attempt to clean all connections and check for power. Thanks for the reply
Old Mar 25, 2022 | 04:49 PM
Figured it out, the little Grey connector on the firewall that has the blue and yellow wire running through it was the problem, the male end of the wire came apart from the female insert.
Old Aug 2, 2022 | 03:43 PM
Iyoy's Avatar
Congratulations!Good job figuring that out! I was about to suggest replacing the battery cables which I did and it solved my similar problem. Now I will go back and check that connector you mentioned. Could you please post a picture of that connector? Thanks!
shobin
May 24, 2021 06:30 AM
Atlantis
Apr 14, 2020 07:13 PM
87roadwarrior
Aug 26, 2015 10:26 PM
dnarby
Mar 31, 2012 08:36 PM
ijourneaux
Nov 25, 2011 06:45 PM
